E-Class (W211) 2003-2009
Gas leaking while pumping
Old Dec 22, 2015 | 06:52 PM
sriramt's Avatar
1999 E320 4Matic
When I fill gas, the gas leaks from the bottom, probably looks like from the overflow. Not a lot, but sufficient enough to smell. Once I stop filling, it gradually stops or when I drive it fully stops. Anyone know what is going on? Vent Value or something not working?
I have a 1999 E320 4Matic.
Looks like I have a 3/4 of a tank before I take it to the mechanic :-)
Thanks for any suggestions.
Old Dec 22, 2015 | 08:01 PM
sriramt's Avatar
1999 E320 4Matic
I just checked for codes and here are the codes P0446 P0450 and P0173.
Old Dec 22, 2015 | 08:17 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Would that be W211, the tank would be under recall warranty, but looks like you have W210
Old Dec 22, 2015 | 08:31 PM
sriramt's Avatar
1999 E320 4Matic
thanks Kajtek1. is this a bad tank or charcoal canister?
Old Dec 22, 2015 | 09:37 PM
kajtek1's Avatar
Investigate it ASAP.
W210 has tank behind the seat, so would that be tank leak, you'd have strong smell inside.
Old Dec 23, 2015 | 12:31 PM
sriramt's Avatar
1999 E320 4Matic
Thanks kajtek1. I have an appointment for Monday to check this one out.
