E-Class (W211) 2003-2009
headlight wires
Old Feb 16, 2016 | 12:04 AM
alexqkama's Avatar
2006 C230 with 139k and 2005 C240 4matic
Question headlight wires
The headlights wires insulation are gone in most parts of the wires. Can I replace the wires without removing the assembly? I am not getting a blown bulb but I have a battery draw and the fuse 64 has 1.8 amps draw.
Old Feb 16, 2016 | 08:55 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
fuse 64 is your interior light switch fuse.... I would unplug the switch and see if the current draw drops to spec (.030-.060milli amps). the w211 usually has a higher current draw then other models for whatever the reason. Especially the older ones.
Old Feb 16, 2016 | 08:57 AM
cmriv's Avatar
oh, that fuse also has your AAC circuit on it as well.
Old Feb 16, 2016 | 11:30 PM
Heatwave's Avatar
Veteran: Navy
2007 E350; 2018 GLE350
As an alternative to replacing the wires on which the insulation has disappeared, you might try painting them with liquid electrical tape: Liquid Tape is the name-brand I've used for similar repairs. Works. Available at auto parts stores, Home Depot, Lowe's, etc.
Old Feb 17, 2016 | 01:32 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
I just opened up my headlights and found the same problem in the wiring inside the housings - much of the insulation had cracked & flaked off. I just wrapped them in electrical tape.
