E-Class (W211) 2003-2009
How to replace the SBC pump on a w211
Rating: Thread Rating: 2 votes, 3.00 average.
Old Jan 26, 2017 | 01:35 PM
  #76
nivram13's Avatar
E240 -2003 E55 AMG -2005
Question on SBC part numbers my current SBC part number is A 005 431 72 12 Q1
The only replacement I can source locally here in New Zealand is part number A 005 431 71 12 Q1 will this still work my vehicle is a 2005 E55 ??
Old Jan 26, 2017 | 02:31 PM
  #77
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
Will not work unfortunately
Old Jan 26, 2017 | 03:22 PM
  #78
nivram13's Avatar
Thanks do you have this part in stock please?
A 005 431 72 12 Q1
Old Jan 27, 2017 | 08:32 AM
  #79
FCPEuro's Avatar
Mercedes
I don't show that number in my system, based on your model year I suspect you need a 0054317312 equivalent however feel free to send me your VIN so that I can confirm what matches.
--Kyle
Old Jan 28, 2017 | 10:08 PM
  #80
nivram13's Avatar
--Kyle
Thanks VIN is WDB2110762A766351
Old Jan 29, 2017 | 10:26 AM
  #81
konigstiger's Avatar
'71 Pinto
EPC shows 0054317312 replaced by 0054318112, see attachment.
File Type: pdf
Old Jan 30, 2017 | 01:27 AM
  #82
FCPEuro's Avatar
Mercedes
Mercedes is showing 0054318112 is now 0094312712. I offer the pump at this link:
https://www.fcpeuro.com/products/mer...r-009431271288
Please note, I have not added the E-Class models to the fitment guide however it is compatible.
Old Jan 30, 2017 | 01:37 PM
  #83
CDIJeff's Avatar
2005 E320 CDI
I really should learn how to use half of the other programs on my Star tool other then Xentry.
Old Apr 6, 2017 | 12:45 PM
  #84
Gangrene3075's Avatar
03' Mercedes-Benz E500
I see www.eeuroparts.com is now offering a Mercedes-Benz Electronic Brake Service Tool that can Deactivate/Re-activate SBC and change brake fluid for $24.99 (3 week Rental). Looks interesting.
Old Apr 6, 2017 | 12:58 PM
  #85
isthisit's Avatar
2006 E320 CDI
Originally Posted by Gangrene3075
I see www.eeuroparts.com is now offering a Mercedes-Benz Electronic Brake Service Tool that can Deactivate/Re-activate SBC and change brake fluid for $24.99. Looks interesting.
That is a great deal, I love those guys. They're just up the road from me and
are very knowledgeable. If they sell it then it's good. I have Star so it's a moot point for me but I assume many people would benefit from this tool.
Nice find!
Old Apr 6, 2017 | 08:00 PM
  #86
CDIJeff's Avatar
2005 E320 CDI
Yeah its nice there are options now / more information on what OBD will work with SBC. I was looking at this system it allows you to disable brakes its called the EP21 according to the sticker. Only down side people have stated on reviews is that does not pull codes only disables brakes and on certain models.
Old May 8, 2017 | 05:54 AM
  #87
Tomzi's Avatar
CLK 500 with Kleemann SC
Originally Posted by CDIJeff
Thought I would give a small update, SBC unit is doing great no squishy pedal or anything. I did however find out my new SBC unit now has SBC hold option. Not sure if they were programmed that way for USA, however mine has it. Not sure of how to turn it off in Xentry if I ever wanted to. Found this out by accident when stretching my legs and pressed the brake pedal further down.
Hold up! Just to be clear, you didn't have SBC H before you swapped out the SBC pump? I know that cars before march 2003 did not have it.
My 2002 E500 does not have it and I need to replace my pump, im deciding whether or not to sell the car or replace the pump, getting SBC H is a big PRO reason not selling the car lol.
Old May 8, 2017 | 07:59 AM
  #88
cMazara's Avatar
w211 03'
Hey CDI, can you tell me the part number of your old sbc and your new sbc unit please.
Old May 10, 2017 | 10:43 AM
  #89
CDIJeff's Avatar
2005 E320 CDI
Yes that is correct.
Old May 10, 2017 | 10:45 AM
  #90
CDIJeff's Avatar
2005 E320 CDI
The only numbers I have are in the photos, I can get the new SBC unit number however it will be a while not near my car.
Old May 11, 2017 | 01:46 AM
  #91
scotty68's Avatar
E320 CDI
people getting rid of their worm sbc, pm me.
Old Aug 19, 2017 | 11:06 PM
  #92
gotglasses's Avatar
2015 SL400 and 2004 SL500
MBII scanner for this?
Originally Posted by mhebb123
Did you ever try this with the iCarsoft MB II?
I have same concern - I bought the icarsoft MBII to read codes and do some ABC and brake work on my SL500.
The MBII does disable the SBC for pad changes and it gives a scary red brake SBC failure warning but no real feedback other than turning it back on to get rid of error message.
I'd guess that if I tried this SBC replacement that I could not activate the counter without the Mercedes shop machine. Is that the only way?
Old Aug 23, 2017 | 02:52 PM
  #93
ngocrebel's Avatar
2003 E500
Should I replace SBC for my '03 E500 too?
Hello members
First, Thanks OP for the great write up.
I bought my '03 E500 a year ago, the odo is 106000 miles now.
I did valve gaskets and breathing hoses replacement, rear main seal replacement with complete ATF flush, steering fluid replacement, rear transfer case/differential fluid replacement. I also replace brake pads and flush brake fluid without knowing that SBC need to be deactivated.
The car run very nice except the brake warning. IC shows the White brake service warning, sometime it shows RED warning and the car actually stop the for couple times.
I replace brake pedal switch without reset its counter.
Sometime my scanner show auxiliary bat went bad but its measure was 12v plus.
I heard that my '03 E500 model has known SBC unit defect. I don't know if it ever been replace. Sometime I heard the SBC sound very loud.
Well, before i drop $1500 for the SBC, Aux bat, Brake fluid and tool from the link at post #84 I love to have some advice from you guys.
Did I miss anything or the SBC actually went bad.
Thank you and have a great day.
Old Sep 10, 2017 | 08:26 PM
  #94
ellswort's Avatar
1998 C230, 1994 E320
Red death message after brake repair
I am seeking advice regarding repair of a 2004 e320 base wagon.
About a month ago the rear air suspension went out and I replaced both rear air springs following the DIY instructions on the forum. Everything went well, suspension worked fine after the repair for a month or so. Then the brake pad wear sensor message began to be displayed on the vehicle.
I knew the back brake pads were like new so I read the DIY for front brake pad and rotor replacement (disconnect negative battery terminal, disconnect SBC, replace pads and rotors one wheel at a time as outlined, pump brake pedal, check brake fluid level, connect SBC and then the battery). However, the driver side brake wear sensor was broken when I did this so I installed without the sensor ().
When I started the vehicle, the red stop sign with BRAKE symbol was shown and the vehicle was locked in park. I then purchased the sensor, repeated the preparation steps in the repair process and installed the sensor hoping that would resolve the issue. After installation as before, the EPS, ABS and Brake malfunction messages were displayed and the transmission was locked in park.
From the forum it was clear the next step was to obtain a Master Inquiry to determine when and if the SBC unit had been replaced in the past. The unit was replaced in Oct. 2014, the vehicle has been driven 30K miles since replacement.
Reading posts from others it seemed the next thing to do was to obtain the STAR diagnosis and code report. I had the vehicle towed to the nearest dealer (40 miles), waited 3 days for the dealer diagnosis and I now have the codes.
The codes are C249B, C24CD, P2404, P2010, 9033, 9034 and 9092. The dealer (Fresno, CA) would not give me a printout of the codes, but he said these are the main ones which all indicate SBC control unit replacement ($2417 plus tax).
I have several questions for the forum.
Does it seem plausible that the SBC unit would be bad after 30K miles and 3 years?
Second, if so, should I consider replacing this myself (I read the DIY SBC unit replacement instructions which required the STAR diagnosis equipment, with a cost of ~$1K for parts and then the additional cost of the STAR equipment and Dell HDD.) or is this something I should just go ahead and accept as a consequence of buying a high maintenance vehicle?
For the DIY SBC replacement, any suggestions on which diagnostic unit to buy and where to purchase it from (or rent with deposit?)
Thank you for all of the excellent info on this forum and in advance for any advice on this topic!!
Old Sep 10, 2017 | 10:53 PM
  #95
cMazara's Avatar
w211 03'
Doesn't seem to be the sbc unit, seems a communication error from the brake wear sensors, should have contacted an indie shop which would tell you exactly what the computer tells...
change the brake pedal sensor, second check whether the sensors are installed correctly, I would assume that brought the problem and reset..
If you do everything at the dealer,, then yes, it will be really expensive..
Old Sep 11, 2017 | 01:44 AM
  #96
ellswort's Avatar
cMazara,
Thank you for your insight and suggestions. I will replace the brake pedal sensor. I assume that after replacement of the sensor I will need a shop to reset the codes, etc.?
Before towing to the dealer, I had removed the tire and double-checked to ensure the sensors were inserted fully and installed correctly with the driver side sensor on the driver side, etc. (that assumes that the handwritten labels identifying driver/passenger side were correct, which also guided which pads went on each side). So I do not believe the sensors are installed correctly.
I am going to show my ignorance now...when you say indie shop, is that an independent shop that works on MB, such as can be found via:
https://www.benzshops.com/search?
I had not thought of searching for such shops, there are several within 30 miles of my home.
ink that is the issue. This car is my fifth Mercedes, and my wife loves the car but it seems to be considerably higher maintenance than the others.
Old Sep 11, 2017 | 08:02 AM
  #97
cMazara's Avatar
w211 03'
cMazara,
Yes, the brake pedal switch is just like 15 usd , it maybe not the issue but it goes bad and causes this, so it'll be good to change it anyways and you could do it yourself. http://www.mercedesmedic.com/brake-d...e-c249f-fault/
I personally don't believe it's the sbc itself, since the fault was triggered by something else.. Could also be the pressure accumulator, which is 120 usd part and a shop to change it that knows and has the sd star computer. (you need the star das to set up the new part, that's what I saw when changing mine, I think it needs bleeding though das.)
When I had the sbc bad, I would let the car sit for a couple of hours, then it will reset everything, even all those sbc errors and you could move it out of park.
Yes, indie are in this case mb specialist that are not the dealer. I've seen that in the usa they charge from 80 to 150 I think to check the car with the computer and reset it.
Who knows, maybe erasing all the codes will fix the issue, but surely the sd computer will tell you exactly what it is, sbc pump coes can be triggered by a lot of things.
Well, true and false.. I'm dying all my faults, like the heat exchange valve which is just 50 usd, the transmission which all around is like 300 usd, parking sensors 25 usd.. It's an expensive repairs depending if it's on the dealer and where you source the parts.
Old Nov 8, 2017 | 09:22 AM
  #98
LexBrett2's Avatar
2007 Mercedes E550
Is it possible to use the iCarsoft MB II instead of the Star/Multiplexer for this procedure?
Old Nov 8, 2017 | 05:28 PM
  #99
nivram13's Avatar
No iCarsoft dose not support the brake bleed function
Old Nov 8, 2017 | 09:07 PM
  #100
cMazara's Avatar
w211 03'
you can disable the sbc, but that’s it. Changing the sbc involves a few steps in sequence that the star has, bleed corner by corner, check pressure and values.
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
