resetting codes
Less than $50 will get you a basic OBD-II reader, which will safely clear most codes. A couple hundred dollars (still way less than one of the many computers on the car) will get you a good scanner that will read/clear just about any codes (engine, transmission, body, brakes, etc.) that your car can throw.
If you decide to to the "free" option your mechanic suggests, let us know how much it ends up costing...
*I'm not trying to be a smarta$$ but seriously: I wouldn't even consider doing it the way he suggests.
Alternatively, you can spend about $20 on a bluetooth OBD2 reader from amazon that will work with your phone. You can use that with the Torque app on any android device to reset ECU, check codes, view live data etc..
Any you guys could recommend around the $50-100 range for general use?
Anybody got some input or experience with this?
