E-Class (W211) 2003-2009
A/C
Old Mar 8, 2016 | 10:45 AM
alexqkama's Avatar
2006 C230 with 139k and 2005 C240 4matic
A/C
My mechanic said the compressor is weak and he could not get any reading codes on the scanner. A/C is not blowing cold air. He wants me to buy a new compressor. Is there such thing that the compressor is weak?
Old Mar 8, 2016 | 10:51 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
When compressor wears out, it will not deliver the required pressure, so you can call it weak.
I would seek 2nd opinion. MB compressors last very long time.
What is the mileage?
Old Mar 8, 2016 | 10:58 AM
alexqkama's Avatar
I got it from the junk yard because my original one was working but making grinding sounds.
Old Mar 8, 2016 | 11:01 AM
alexqkama's Avatar
My question is that the mechanic could read coeds from the compressor, is that possible when it is weak or there might be other issues
Old Mar 8, 2016 | 11:07 AM
kajtek1's Avatar
Variable output compressors takes some knowledge to troubleshot and the car system has about 8 sensors that affect the output.
For full troubleshooting you need the sensor readouts with cold car engine off and then on hot day when you turn AC on.
I am happy to have clmatronic where I can read the sensors while driving, but for some reason MB deleted the option on standart W211
Old Mar 9, 2016 | 10:40 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
evac/recharge and inject dye. road test 15 miles or so and check for leaks. Step 1.
Old Mar 9, 2016 | 10:43 AM
cmriv's Avatar
step 2, find someone with das/xentry. check actual values/guided tests.....
