E-Class (W211) 2003-2009
Rear end vibration like clockwork
Old May 1, 2016 | 09:45 PM
EMFAudio's Avatar
2014 ML63 AMG, 2012 McLaren MP4-12C, 1999 GMC Sierra, 1994 Chevy Astro, 1990 Honda CRX
I believe my issue is SOLVED
Now the solution. I did the "I wanna burn off a set of tires" ECU reset which as a side effect corrected the issue. This tells me it was my brake controller all along, making the driver rear wheel freak out for a little while.
Old May 4, 2016 | 11:00 AM
EMFAudio's Avatar
ECU started re-learning, problem is back. Now I'm baffled. I took the driver rear wheel off pavement and it doesn't seem to have any weirdness to it, no play, spins fine. However, I obviously can't spin it by hand 30 MPH to see if that changes.
Old May 8, 2016 | 01:49 PM
EMFAudio's Avatar
Issue appears to be resolved now, not what I expected.
I had a tear in an air line coming off the airmatic compressor, making it vibrate more than usual, and it happened to feel like it was coming from the rear for whatever reason.
