E-Class (W211) 2003-2009
S211 Opening the hood
Old Mar 20, 2016 | 09:58 AM
Stile's Avatar
W204 C63 AMG
Hey guys!
Any tips to get hood open from the outside?
Batteries completely empty and metal key does not work.
Old Mar 20, 2016 | 01:15 PM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
Why you want open the hood? Are doors now locked, metal key works not in doors/trunk?
There are some threads where are instructions how to release hood locks from underside, but they are very well hidden and without seeing what kind of clamp system is, it is very difficult. Some says opening cable would be visible if you remove driver side front wheel liner, but at least in my car cable goes in engine bay and goes through fire plate to footwell direction.
Old Mar 20, 2016 | 01:34 PM
Stile's Avatar
W204 C63 AMG
Yes, doors are locked and metal key does not work. Estate does not have a lock on the boot lid.
Old Mar 20, 2016 | 01:49 PM
mersum1es's Avatar
OK, here some threads I have bookmarked:
https://mbworld.org/forums/e-class-w...ight-side.html
http://www.mbclub.co.uk/forums/parts...-problems.html
https://www.youtube.com/watch?v=CpAK...ature=youtu.be
Old Mar 20, 2016 | 08:14 PM
samaritrey's Avatar
Super Moderator
THE C350
Is it the wrong metal key or are the door locks broken?
What good is it to open the hood?
Old Mar 20, 2016 | 10:24 PM
cetialpha5's Avatar
Does the key turn in the lock or not at all? On the sedans with a trunk, you have to turn the key and lift while the key is turned in order to open the trunk. I wonder if it's the same with the front doors.
Otherwise the simple answer in the US would be to call a tow truck, they can usually use a device to open the door and once it's open, you'll be able to get at the battery.
Old Mar 21, 2016 | 09:49 AM
Stile's Avatar
W204 C63 AMG
The key is right and lock should be ok. It turns 45 degrees both ways, but nothing happens.
Old Mar 21, 2016 | 01:22 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
You might try to push it harder to go past 45 degree.
I assume you want to get to jumping prongs under the hood?
I wonder if your car might have main cable connection exposed at underbody.
Old Mar 22, 2016 | 11:39 AM
mersum1es's Avatar
Originally Posted by Plutoe
Call the local police---they have much knowledge about braking into cars!!
Finnish police and 'modern' (yes car of this age are just average aged) mercedes - I doubt Though they have a nice CLS patrol car: http://1w44ss1jnx032s2jqt2i66qmfrx.w...to-495x329.jpg
Then like above, some models/engines have alternator power feed reachable underneath.
Old Mar 22, 2016 | 11:47 AM
kajtek1's Avatar
I check wife wagon and the blade needs to turn 90 degree to operate lock.
Give it some workout.
The color scheme on that police MB is ugly like hell.
