E-Class (W211) 2003-2009
e500 changed battery issues
Old Mar 27, 2016 | 04:20 PM
cwilliam83's Avatar
e500 2003
I just changed the battery in the car because the other battery died. After changing the battery the air pump doesn't start and the audio buttons and radio soft buttons don't work any help would be great thanks
Old Mar 27, 2016 | 05:21 PM
wjcandee's Avatar
2004 Mercedes E500, 2008 Mercedes ML350
I don't know, man. None of those things should be an issue after changing the battery. Are you sure that everything is connected up properly, and that the battery was adequately charged? I would pull the battery out, put it on a charger, make sure that it is a group 49 or L5 or h8 size battery. Those are all the same size, just different ways of expressing the size. And I would make sure that it's fully charged. Then, I would put it back in, hooking the positive up first, then the negative. Then I would go through the procedure to reset the stability program, Windows, and sunroof. Those are posted Elsewhere on the Forum. Then, it should be fine. An AGM battery is recommended, but a sealed vrla battery will also work on our car. Be sure you have one of those two. That's about all I could suggest.
Old Mar 27, 2016 | 05:43 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
The car should have an AGM battery. Is that the type you replaced it with? Ditto on check all connections.
Old Mar 27, 2016 | 11:45 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
What battery did you change and what else did you do?
Those cars left factory with flooded battery.
AGM is optional if you really want it.
Old Mar 28, 2016 | 12:38 PM
cwilliam83's Avatar
e500 2003
The battery is an H8 AGM Battery. Replaced the battery in Trunk. Went through the procedure to reset the stability program, Windows, and sunroof. Still have issue with those 2 things.
Old Mar 29, 2016 | 01:44 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
but your aux battery??? Battery control module also... Look for corrosion around unit.
