Fuel odor upon fill-up
So here's my question: If your W211 had a similar problem and it was repaired under the aforementioned extended warranty, did the repairs solve the problem? Which components were replaced?
Thanks in advance for all responses.
relinuca
Keep us posted how the inspection goes and check the forum HOW to describe the problem
Out of principals I would call 800 FOR MERC and report that dealer refused to honor warranty till you kicked him
I wonder how many busy professionals who drive MB and don't have time to read forums - simply pay up?
The smell, that's another story - in the meantime, while you get it fixed just don't top it off when you fuel up.
Thanks for the vote of confidence.
I had wire burning out on fuel pump in ML55.
The pump was inside fuel tank. Can you picture sparking and melting electrical wire submerged in fuel???
But there is no oxygen in fuel tank, so MB never had a recall on those things, although they went extra way to keep the knowledge from the public.
Frankly even I agree that fuel vapors under rear seat are not high danger for car fire - I would make DW to practice fast vehicle exiting.
this a safety hazard. And is somewhat dangerous. There are electrical components inside and outside of fuel tank. Also if tank is leaking, then there is oxygen somewhere that could mix with evaporated fuel. A puddle of gas chilling near your electrical connectors for your sending units isn't exactly safe by any means.... If the puddle is large and leaks down/behind fuel tank directly about your exhaust pipes, then yes, Hommies wife has all reason to be afraid to drive. Chances of that happening slim, however you know how some people are.
Kajtek1 is correct, you should say something about the dealership trying to pull the "WE are unaware of such things" I'm calling BS. And he is also correct in regards to something being shorted and causing a spark.
Anyone had any luck trying to fix the crack\split in tank\filler neck themselves?
I know NZ is having much smaller population of lawyers, that is probably why you don't have recall there, but depends how good relation you have with your local MB representative, you can print pdf above and ask them for goodwill repair/replacement.
Good luck.
relinuca
