E-Class (W211) 2003-2009
Metallic Paint
Old Mar 30, 2002 | 05:01 PM
Sean's Avatar
1999 Porsche 911 Carrera
Question Metallic Paint
Can anyone help me out with the pros and cons of Metallic Paint?
From what I understand, the paint shows better after a few years and is more durable; however the cost of repair may be higher.
Any input is greatly appreciated.Thanks
Old Mar 31, 2002 | 06:06 PM
Hal H's Avatar
2001 CLK320
All modern paints...
have clear coat - whether its a solid or metallic paint finish.
A shop that is using the OEM paint can usually produce the same particle size and shading if a section has to be repainted due to a scratch or body damage.
Cons: If you had a really faded paint - this gets harder to match, as the new paint might appear a deeper tone than the older part.
Dark metallics won't stand up to neglect (outside in the elements, not being polished and waxed regularly) and look their best. The dark colors absorb more UV and can oxidize more quickly.
If the clear coat gets dull or hazy, it will really show up a lot. Another thing is swirl marks from not polishing carefully will show up...(lots of posts here about that)
Other than that, keep it washed regularly and waxed, and you'll be in good shape.
Old Apr 1, 2002 | 09:51 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
I would not worry about it. Buy the color you like.
