E-Class (W211) 2003-2009
Service Brake Warning Display
Old Apr 24, 2016 | 01:26 PM
EclipsedEvo's Avatar
I know that this has been discussed before, but I wasnt able to find the correct answer. On my 2004 E320, I had the "Service Brake Visit Workshop" display error and noticed my rear pads were almost gone. i replaced the rear brake pads and got new brake sensors. However, the service brake display is still on. Do I need to reset the SBC? Need a diagnostic tool? Any info is greatly appreciated. Thanks.
Old Apr 24, 2016 | 02:44 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Generic message might have several sources.
Are you saying front pads are still good.
If pads are good, you need to read the error with SD.
Old Apr 24, 2016 | 03:01 PM
konigstiger's Avatar
'71 Pinto
Definitive diagnose pull codes with MB SDS.
If steadfast on replacing parts before doing so some members cleared warning by replacing the brake light switch https://mbworld.org/forums/e-class-w...-easy-diy.html
However, if SBC hydraulic unit has not been replaced common scenario SBC hydraulic unit reached its operating limit and needs replacement confirmed by SDS. IMHO replace rather than reset but I’m sure others will offer their opinions.
MB extended SBC warranty to 10 years/unlimited mileage but unfortunately you are past expiration, DIY https://mbworld.org/forums/e-class-w...pump-w211.html
Old Apr 25, 2016 | 12:08 AM
Thanks guys for the info! I'll find a MBZ SDS and read the code.
Old May 5, 2016 | 11:29 PM
nphra's Avatar
2004 E55 AMG
Any updates on this isssue?, i have the same problems after replacing all 4 rotor, brake pads and sensor. Let me know you ablle to fix it.
Old May 5, 2016 | 11:50 PM
I actually just got the car back. It had two error codes: c25d2 and c2131. Basically, the pressure reservoir of the SBC was faulty. I went ahead and got the entire SBC replaced as there wasn't much price difference. Damn SBC.
Old May 6, 2016 | 12:20 PM
thtguy's Avatar
2017 GLS 550
How much did that set you back? the reservoir is around $190 online.
