E-Class (W211) 2003-2009
Small headlight flickering
Old May 13, 2016 | 03:08 PM
Junaid6305's Avatar
W211 E Class, W124 E Class
The Small headlight on one side keeps flickering when you unlock the car (and the lights come on as they're supposed to) and while driving. They were changed to LEDs. I think it might be a lose connection as it sometimes says on at normal brightness for a couple seconds then continues to flicker.
Old May 15, 2016 | 10:42 PM
samaritrey's Avatar
Super Moderator
THE C350
Probably a resistor on the LED going out (had this issue to many times so switched back to normal bulbs). I would either test with a known working bulb or get out a volt meter and see if you can find any issues.
