E-Class (W211) 2003-2009
Wiring problem 320 cdi
Old May 16, 2016 | 12:48 PM
Itzikp's Avatar
E320cdi
Hi everyone
Recently I baught 05' 320cdi with 648 engine (straight six)
The car was in limp mode since I baught it for several problems
Now,after I remove the inlet shut off flaps,i taught I could just replace the jamming motor for the 4.7k ohm resistor,witch didn't work,I checked the wiring and found out the signal wire that goes from the motor connector back to the ecu is disconnected, searched for ecu pinout or wiring diagram to know to witch PIN number it supposed to be connect,if anyone have the pinout or the inlet shut off wiring diagram it will help me a lot
Great forum
Regards
Itzik
Old May 17, 2016 | 06:12 AM
Itzikp's Avatar
E320cdi
WDBUF23H15A680147
Old May 24, 2016 | 01:33 PM
Itzikp's Avatar
E320cdi
Thanks a lot
Thanks to your wiring diagram I found out the relative wiring, attached 4.7k ohm resistor and the problem gone,car still has no boost but one less problem on the list to fix
Itzik
