E-Class (W211) 2003-2009
2007 E550
Old Jun 3, 2016 | 02:55 AM
rodneypierce's Avatar
2009 e550 4Matic
Originally Posted by scoobertdoo
The car was $6200, so I figured why bother. Even if I put 3K into it, I am in the good.
you already will be over 3k fixing what you currently need done... And you just keep finding more and more problems with it.
Old Jun 3, 2016 | 08:24 AM
RCPDesigns's Avatar
2007 e350, 2013 C250, 2004 C320, 2003 C320, 1998 CLK 320
Yeah, I agree with Kushp14. $3K is nothing on that car. If possible, run away. Check the laws in your state. If the car doesn't run this soon after you bought it, maybe you can get out.
Old Jun 3, 2016 | 08:49 AM
scoobertdoo's Avatar
e550 2007
Its florida, no lemon law, no warantee
Now the car will only run on 4 cylenders half the time.
P300
P0024
P0304
P0305
P0021
Old Jun 3, 2016 | 07:23 PM
2009 e550 4Matic
dude you have your hands full.. i dont know what else to tell you. take it to a dealer and be ready to open your wallet.
Old Jun 3, 2016 | 08:39 PM
RCPDesigns's Avatar
Could be the CPS. Could be oil in the CPS.
http://www.pelicanparts.com/techarti...eplacement.htm
You really, really, really need to take the car to a Dealer and have them give you a list of problems. Then you can A) decide to keep the car and work through the list yourself, with an Indy and/or with the dealer. Or B) sell the car for a loss and learn the lesson of why you MUST get a PPI.
You quite possibly have bought a car that someone never did the maintenance on and it is falling apart right before your eyes.
Old Jun 5, 2016 | 07:51 AM
e550 2007
What side of the engine is bank two?
I ordered the crankshaft sensor. how would oil get into it?
Old Jun 5, 2016 | 11:10 AM
  #32
d1a1s1's Avatar
2008 E550 4-Matic
I second this recommendation. If nothing else they'll be able to give you a more comprehensive list of problems with estimates on repair. Most dealers will charge about a $150 for this, well worth it in this case.
Old Jun 5, 2016 | 08:44 PM
  #33
e550 2007
If the CPS is bad, how is the tachometer working?
Old Jun 9, 2016 | 07:27 PM
  #34
e550 2007
Crank sensor replaced, no change. Misfire on 3 and 5
Old Jun 9, 2016 | 07:49 PM
  #35
RCPDesigns's Avatar
You've got to do this. You can't throw parts at the car and hope to get lucky.
Old Jun 9, 2016 | 08:13 PM
  #36
e550 2007
I replaced the CPS by a recommendation from here.
Cost: $150.
I do want to get the DX done, and may have it done tomorrow.
Does it have to be mercedes? A local shop told me they have a very expensive computer that will allow them to do the same thing, for less money.
I can call merc tomorrow and get pricing.
Old Jun 9, 2016 | 08:20 PM
  #37
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
Treat it like a 273 engine. Return the crank sensor, you didn't need it. Verify fuel pressure and verify engine timing. Those are my two recommendations on priority focus points right now.
Common 273 engine issues that may cause your symptoms
  • Fuel Pump
  • The Four Cam Adjuster Magnets
  • Incorrect Engine Timing
A factory service manual is a good investment if you are going to spend time and other resources getting the car straight. Mercedes publishes all the information online for a fee. In addition, if you need a service procedure you are welcome to email products@fcpeuro.com and I'll pdf you the info.
--Kyle
Old Jun 9, 2016 | 08:21 PM
  #38
e550 2007
  • Fuel Pump
--Kyle
I am getting an exhaust camshaft code.
Will buy the $15 fuel pressure tester tomorrow.
I thought timing was all electronic?
Old Jun 9, 2016 | 10:19 PM
  #39
RCPDesigns's Avatar
Cost: $150.
My initial advice was to go to the dealer and find out everything that is wrong with your car. I mentioned the CPS as it seemed likely. I had no idea that you'd just go and do that first without finding out all of what is wrong. I will refrain from offering further advice that involves replacing things until you've been able to get a real handle on what you're up against.
I would pay extra and go to a dealer. I have the system that they have and there are significant advantages to having it. Some dealers do take advantage of you and it is more expensive... I get that. FCPEuro is offering very good advice as well.
Let me say this another way. Forget the immediate problem you have with the car now. You need to know all of the problems you have or will likely have soon. A PPI would have told you that. I did a PPI on the C320 I bought last year and it recommend $3800 worth of work to be done. I knew I could handle that work myself so I bought the car. Had it been something different I would have passed. Take the car to a dealer and tell them you'd like to start having the car serviced there. Tell them that your budget is tight, so could they go through the car, bumper to bumper, and make you a list of all the things that need attention or will need attention soon so that you can prioritize what you are going to do. Whether you take that list and do it yourself, find an Indy or run like hell it doesn't really matter at this time. Please just find out what you're up against. Maybe it is nothing... would be great to know that.
Old Jun 9, 2016 | 10:21 PM
  #40
e550 2007
Let me say this another way. Forget the immediate problem you have with the car now. You need to know all of the problems you have are will likely have soon. A PPI would have told you that. I did a PPI on the C320 I bought last year and it recommend $3800 worth of work to be done. I knew I could handle that work myself so I bought the car. Had it been something different I would have passed. Take the car to a dealer and tell them you'd like to start having the car serviced there. Tell them that your budget is tight, so could they go through the car, bumper to bumper, and make you a list of all the things that need attention or will need attention soon so that you can prioritize what you are going to do. Whether you take that list and do it yourself, find an Indy or run like hell it doesn't really matter at this time. Please just find out what you're up against. Maybe it is nothing... would be great to know that.
What should I expect to pay, on a bumper to bumper test to find all the issues? I don't want to be told $500 and think that is a normal price for such a thing.
Old Jun 9, 2016 | 11:15 PM
  #41
RCPDesigns's Avatar
It depends on the dealer. If they really want your business they might do it for free. I paid around (or just under) $200 for my last PPI from a Mercedes Indy. These guys have DAS and they only work on Mercedes and they are not cheap, though slight better than a dealer. I think you said you were in Florida? I'm sure there are two dealers within decent driving distance. Give 'em a call, ask for the service center and tell them you just bought a Mercedes and are figuring out where to get it serviced. Ask them how much it would cost for them to go over the car and work out a plan for you. Let them compete for you. They'd be crazy to throw out a high number. If it is over $250 then find an Indy. There are plenty of forum members in Florida. Post a topic asking for best Indy in your area.
Old Jun 10, 2016 | 07:43 AM
  #42
e550 2007
I did ask, and got 0 replys on the indy search. Thou Asking local, I did find one, but he is typically booked weeks out, and charges list price for parts...
Old Jun 10, 2016 | 08:23 AM
  #43
e550 2007
I have an appointment for this morning at the dealer.
The multipoint is free, but the computer diag is $150 an hour.
The car was dealer serviced by this same dealer.
They will give me the car history when I arrive.
Old Jun 10, 2016 | 09:04 AM
  #44
e550 2007
Here is the pressure reading.
Old Jun 10, 2016 | 09:17 AM
  #45
FCPEuro's Avatar
Mercedes
Awesome news, glad to see you got it in for diag. This will save you money and headaches.
--Kyle
Old Jun 10, 2016 | 11:00 AM
  #46
e550 2007
--Kyle
We will see. See if they give me a detailed list, or come back saying replace the entire engine, suspension, and fuel system.
Old Jun 10, 2016 | 12:35 PM
  #47
e550 2007
First hour came and went, they say it's not electrical.
Old Jun 10, 2016 | 02:28 PM
  #48
e550 2007
They believe It is injector 4,
Old Jun 11, 2016 | 03:41 PM
  #49
FCPEuro's Avatar
Mercedes
How did things turn out w/ the inspection?
Old Jun 11, 2016 | 03:57 PM
  #50
e550 2007
That's just it, for 200 they told me I most likely have a bad injector.
He said everything else is good.
