E-Class (W211) 2003-2009
Bi-xenons for W211
Old Mar 12, 2004 | 05:18 PM
Harris's Avatar
Bi-xenons for W211
It is available now. Resetting the computer is required. For pricing info, pls contact harris@hartonmotorwerks.com
Old Mar 13, 2004 | 01:59 AM
Sponger's Avatar
Harris, I take it that bi-xenons are an option on the 211. The housings on the 04's with and without the lighting package look identical.
Old Mar 13, 2004 | 07:49 AM
Tezta's Avatar
CLS350
its true and it threw me off the first time around.. i thought all w211's came with xenons and that the "Bi" function was and option.
Old Mar 13, 2004 | 02:32 PM
Harris's Avatar
Bi-xenons is not a standard feature on W211's. It is an option even on E55s, which is pretty sad.
Old May 12, 2004 | 07:38 PM
Harris's Avatar
New stocks have arrived with better pricing!
Old May 13, 2004 | 02:41 AM
lpolo's Avatar
MBenz
Mmm.. excuse my ignorance, but what is the difference between regular Xenon on 2004 W211 and Bi-Xenon?
Old May 13, 2004 | 05:12 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
There's no "regular Xenon" on 2004 W211 from the factory, only bi-xenon.
-s-
Old May 13, 2004 | 05:45 AM
glojo's Avatar
E-class E300e Estate, Sprinter (stretched limo)
I will offer a short lay persons understanding. Bi-xeon operates both on dip and main beam. I believe it is also brighter.
It is definitely a far superior light than the previous 210 xeon headlamp.
Regards,
John
Whereas the xenon light is only applied to low beam operation (for high beam a separate reflector with conventional halogen bulb is used), the bi-xenon headlamp operates with one single xenon bulb and creates both low beam and high beam. Typically a projector unit (70mm diameter) is used.
The cut-off is generated via a special shield, which forms the typical asymmetric shape of the low beam function with an inclination of the right-hand side. The concept bi-xenon light contains a movable shield, which can be flipped (by means of a solenoid or electrical motor) to remove the cutoff line, to achieve high beam operation
Old May 13, 2004 | 06:58 AM
BooBoo's Avatar
Our local dealer sells the non-dynamic ones for $1,450 a set.
