E-Class (W211) 2003-2009
Stainless steel brake lines and camshaft sensor
Old Aug 25, 2016 | 10:08 PM
phatfire6's Avatar
E550
I need help on a couple things. My E550 has popped an engine code for the exhaust camshaft. I need help identifying which bank is #1. Also is there a picture diagram with the cylinders numbered so I can reference it in the future?
Next on the agenda is the brake lines. I want to do a fluid flush and replace the brake lines since they are cracked. I have a 4matic and I cannot seem to find stainless steel brake lines for the front. Is there something that I am missing? Is there a suitable substitution for 4matics? From what I gather, non 4matic E550s have a stainless steel option available for front and rear, and the rear brake lines are identical between 4wd/2wd. I'm just stuck on the fronts.
Help!
Old Sep 29, 2021 | 07:51 AM
JMD3454's Avatar
2012 E550 Cabriolet
Did you ever get a response on this. I am having the same issue
