Dynamic seat intermittent
What might cause this intermittent problem? Since it sometimes works, I assume most of the components are ok.
Thanks,
Peter
I had "time to build pressure exceeded" (or something in this lane) coming.
Did not tell me much specific, but indication of 2 possibilities.
1. the pump wear out
2. I have a leak
I hooked up pressure gauge and turn out my pump is still building 35 psi just fine.
Than playing with all those connections around tank and pump I had to re-tighten something as right now it works with no errors.
Still hooking up pressure gauge to the system allows for lot of troubleshooting.
I pulled the hose with pressure relieve valve on it and reconnected pressure gauge on the end. It is having rubber hose on the end, so all I needed was thin barber fitting
https://www.aliexpress.com/item/laun...b-8350d284e88c
Oh you can also get it for $38 on eBay, but it's still from China.
http://www.ebay.com/itm/Launch-X431-...2&var=&vxp=mtr
