E-Class (W211) 2003-2009
air suspension
Old Sep 10, 2016 | 09:27 PM
alexqkama's Avatar
2006 C230 with 139k and 2005 C240 4matic
air suspension
Anyone can post a clear video on how to replace the rear air suspension shocks for the e500 2006...
Thank you
Old Sep 13, 2016 | 11:50 PM
Tupperwolf's Avatar
'05 CLK55 AMG Cab, '16 E350 4Matic Wagon
Check youtube. There is one by Arnott showing how to replace the air springs without lowering the subframe. This only works if you are using their springs that don't require the use of the reservoirs.
BTW if you use the Arnott air springs.. just take a good sharp knife and cut the hoses that go to the reservoirs.
Old Sep 14, 2016 | 08:16 AM
F1Fan's Avatar
Are you asking about the shock or the air spring? Because in the rear, these are two different parts. The shock, made by Bilstein, is easily replaceable. The air spring however can be a big task. Replacement air springs by Arnott make the job easier by not removing certain unnecessary parts.
