E-Class (W211) 2003-2009
engine discussion
Old Mar 19, 2004 | 11:19 AM
moretorque's Avatar
Question engine discussion
i am curious why is that mercedes engines has less power output compared to bmws?
for example E320 produces 221hp with 232 pounds of torque whereas the smaller capacity 530i produces 231hp with 300 pounds or torque. mercedes has only begun producing variable timing engines whereas bmw has long since used vanos.
both manufacturers produce great F1 engines.
does it have anything got to do with long term durability? 10 years down the road? or is it that mercedes benz is just slacking in technology?
any opinions guys?
i currently own an E320, Advantgarde. sunroof, airmatic
Old Mar 19, 2004 | 11:23 AM
moretorque's Avatar
id like to add another point....mercedes cars cost more than bmws. why is this?
Old Mar 19, 2004 | 11:35 AM
Davel's Avatar
03 Eclass, 03 BMW 06 Porsche Cayman S, 03 Harley Davidson "bored & stroked"
Check your numbers...
[QUOTE]Originally posted by moretorque
[B]i am curious why is that mercedes engines has less power output compared to bmws?
The correct numbers are 530I:
HP 225 @5900 rpms TQ 214 @ 3500 rpms
E320:
HP 221 @5600 rpms TQ 232 @3000 rpms
The Eclass numbers are more suited for an automatic transmission the the BMW giving the Eclass a stronger off-the-line feel. Also the Eclass puts out 80% of its torques at 1800 rpms...
Old Mar 19, 2004 | 11:36 AM
moa4r's Avatar
S4
Re: Check your numbers...
that better, I was thinking to myself, damn, the 530 has that much torque??!!!!
Old Mar 19, 2004 | 12:33 PM
Adobe's Avatar
You might also ask why BMW V8's produce 100 more HP than the similar sized Ford/Mercury/Lincoln V8.
Also, Mercedes F1 engines are designed, developed and manufactured by Ilmor of Brixworth, England. They are a subsidiary of Mercedes and used to build the F1 engines for GM. Mercedes are at least part owners in Ilmor.
BMW do their own (I believe) and so do Ferrari (with the help of a Japanese engineer who did the Honda F1 engines). Of course Cosworth and several other F1 engines come from England.
Old Mar 19, 2004 | 12:52 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
it may be that case now...but when the 350 engine makes it to the E class, that engine will output 268hp/258tq 4 valves/cyl, etc.
Old Mar 19, 2004 | 01:03 PM
moretorque's Avatar
oppss yeah...sorry about the wrong torque figures
Old Mar 19, 2004 | 01:06 PM
moretorque's Avatar
hmmm..but this doesnt answer why bmw produces more power overall..... the 350 engines power is increased due to its displlacement.
Old Mar 19, 2004 | 01:48 PM
E500 Sport's Avatar
E500
Mercedes Engines are tuned to have low end torque which will sacrifice housepower. If you look at the figures Mercedes have most of it torque is available below 1850rpm. This actually is very much American Engine design philosophy. But consider this, in america typical driving you use torque power much more than horsepower (which only peaks when you floor the pedel and rev up the 6000rpm.)
Old Mar 19, 2004 | 03:32 PM
DMI+RY's Avatar
W220
Question
Any idea when 350 engine comes out for E-Class?
Old Mar 19, 2004 | 05:39 PM
nyca's Avatar
looking like 2006 for the E350. sales are strong, why change anything.
