E-Class (W211) 2003-2009
Radiator Cooling Fan - High Speed Mode
Old Oct 13, 2016 | 05:27 PM
Marsaydeez's Avatar
2008 E350
Hello, my radiator cooling fan turns on high speed, very fast and loud, immediately after starting car, even with cold engine. Air conditioning works, heater vents work, and car doesn't overheat. This happened after the car sat for 2 days. I've researched online and found it could possibly the fan or coolant temp sensor. The car was fine before and I have no CEL. Every time I start the car the fan turns on immediately very fast and loud. I have a 2008 E350 4Matic. Does anyone have an idea what it could be? Any help is greatly appreciated. Thank you!
Old Oct 14, 2016 | 02:36 PM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
Usually it means lack of voltage of some part between modules and ECU. Check all fuses, check voltage feeds and grounding leads (charge battery full). Check no water damage in front or rear SAM (same time when you check fuses). After that like suggested above it might be faulty sensor or fan control... decent code reader will help pinpoint fault then.
Old Oct 17, 2016 | 06:32 PM
Marsaydeez's Avatar
2008 E350
Thank you! I topped off coolant, replaced relay (circuit 87) and fan is back to normal.
