E-Class (W211) 2003-2009
'03 E320 Stalling Running Rich
Old Nov 1, 2016 | 03:49 PM
VB2NC's Avatar
'02 CLK320 Sport
Here's my dilemma. After running some errands on Saturday, I did some work around the house. When I got back in the car 2 hours later, it started, but would barely idle, stumble, stall and was running very rich. I replaced the cam position sensor and it ran perfectly. One hour after, it was back to barely starting/stalling and very rich again. I put in another Cam sensor, still no better. I've cleaned the MAF. The spark plugs, crank position sensor and O2 sensors have all been replaced in the last 5000 miles. No codes at all. Any ideas on what to try next?
Old Nov 1, 2016 | 05:22 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
how do you know it's running rich?
Old Nov 1, 2016 | 05:24 PM
cmriv's Avatar
and no codes as in vehicle was scanned with sds or your cliche advance auto scanner? Sds will allow you to look at smooth engine running....
Old Nov 2, 2016 | 08:39 AM
VB2NC's Avatar
'02 CLK320 Sport
You can smell the gas in the exhaust and it is black. Unfortunately, the only reader I have is a generic one. The closest dealer is over two hours away from me and the closest good indy with SDS, is over an hour away. Nothing shows up on the dash either.
Old Nov 4, 2016 | 10:14 PM
F1Fan's Avatar
My bet is a faulty MAF. I also tried cleaning my MAF but it did nothing. Once I replaced it, the engine ran normally. No stalling.
Old Nov 5, 2016 | 02:55 PM
cmriv's Avatar
maybe the plug wires and or a coil pack is dropping out at times....
