E-Class (W211) 2003-2009
Should the headlights have gaskets around them?
Old Nov 12, 2016 | 05:38 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Arrow Should the headlights have gaskets around them?
So I am taking off my passenger headlight and notice there is no gasket. But this plastic piece.I received a headlight from ebay which is from an 07-09 model and noticed it had a gasket all around the headlight like our CLK.
Couple pictures attached. I noticed that neither my driver/passenger headlight have these... Should I take of the plastic piece and purchase the actual gasket pictured that came with the one headlight? Is this something that the factory bi-xenon came with and the halogens didn't or some years did/did not? I can't imagine why it would not be used but looking on ebay I see some newer lights that have the brackets and others come with the gasket??
EDIT: Browsing around I found part numbers:
Left: http://www.mbpartsworld.com/p/Merced...118200612.html
Right: http://www.mbpartsworld.com/p/Merced...118200512.html
Thanks,
-Nigel
Attached Thumbnails Should the headlights have gaskets around them?-1.jpg   Should the headlights have gaskets around them?-2.jpg   Should the headlights have gaskets around them?-3.jpg   Should the headlights have gaskets around them?-4.jpg   Should the headlights have gaskets around them?-5.jpg
Old Nov 14, 2016 | 04:06 AM
Faniskogen's Avatar
W211 E500 -04
I had gaskets on both my headlights. Also on both used headlights I bought on ebay.
I have a 05 E-class with Bi-xenon.
Old Feb 8, 2021 | 04:13 PM
almostordinary's Avatar
1987 Porsche 911. 2008 G55
Bumping this as I just found out my driver's side doesn't have this gasket and the links provided don't work any longer.
Old Feb 8, 2021 | 04:33 PM
Closest I can find is this number, but can't find a cross ref # 16156300
Old Feb 8, 2021 | 05:04 PM
konigstiger's Avatar
'71 Pinto
Left 2118200512, right 2118200612 https://www.mercedespartscenter.com/
Old Feb 8, 2021 | 05:07 PM
Awesome! Thanks bud
Old Feb 8, 2021 | 05:21 PM
When I pull it up on that site it looks like a seal on the rear of the light housing.
And doesn't look to fit a 2007 E63. Although when I do a google image search elsewhere it comes up as the part that seals the headlight.
Old Feb 8, 2021 | 11:37 PM
E55Greasemonkey's Avatar
This place is a joke.
The facelift 2007-2009 211 does not have rubber gaskets around the headlights like the earlier 2003-2006 models did. I own a 2004 E55 with gaskets and a 2008 E350 wagon without. I can't tell you why because the facelift version sure could use them to fill the gaps.
Old Feb 8, 2021 | 11:41 PM
Well I didn't know anything about these gaskets until I looked at my passenger side and wondered why my driver's side had bigger body gaps.
My 2007 E63 has the gasket on the passenger light and no gasket on the driver's.. I plan on taking the lenses off this spring and putting new lens covers on and now I have to get the driver's gasket/seal.
It definitely has (needs) one.
Old Feb 9, 2021 | 09:32 PM
mildenbenz's Avatar
2013 C250 - Given to daughter. Now a 1982 240D
How about #150 on this page:https://www.ilcats.ru/mercedes/?func...75&language=en
Old Feb 9, 2021 | 10:52 PM
That's exactly it!
When you click to buy from that site it takes you right to a Russian site, while I've purchased a ton for my G55 from Latvia, would love to try to get this local so shipping doesn't take forever.
May call a dealer tomorrow to see what my options are.
Thanks man!
Old Feb 10, 2021 | 09:38 PM
mildenbenz's Avatar
I would never buy from their links, just use the site for part numbers. Not as friendly as a real EPC but definitely like the free resource.
And if the dealer can't help you, I have a left side seal. Doesn't go on my E350.
Old Feb 11, 2021 | 09:14 AM
'71 Pinto
As mentioned seals are pre-facelift and part #s left 2118200512, right 2118200612 are correct, was passenger side ever replaced possibly with pre-facelift headlamp.
