E-Class (W211) 2003-2009
211 E350 4Matic can comms problems
Old Dec 19, 2016 | 12:22 PM
Scott Whitney's Avatar
2008 Mercedes Benz E-350 4Matic
Hello, Ive got a 2008 E350 4Matic that has a bunch of Can communication codes between the ABR/ESP module, the engine module and the steering column module (This module has no stored or pending codes), this happens when cold on initial start up. The symptoms are ESP malfunction, cruise control inop, Pre-safe inop, check engine lamp on TPMS lamp comes on, speedometer is inop and vehicle will not shift out of first gear. The stored codes in the ABR are as follows: C0D43,C3206,C0840.C073D,C3393,C3251. The engine module codes are:P1373 and P0925 the shift module codes are P1876, P2012 the EGS codes are U0121 and lastly the instrument panel has these codes: B1101 and B1104. My issue is available information, i am unfortunatly using ProDemand from Mitchell 1 which sucks out loud!!!!! I know this is a hail Mary throw out for some of you Benz techs but if you have run into a similar problem any help would be greatly appreciated!! FYI New ABR complete hydraulic unit
Old Dec 19, 2016 | 05:32 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
do you have a vin?
Old Dec 19, 2016 | 05:36 PM
cmriv's Avatar
and what occurs after it's warmed up? do other the error messages go away?
Old Dec 20, 2016 | 08:22 AM
Vin # WDBUF87X48B208740 And yes it seems to be cold related, if you drive the car for two to three drive cycles even the engine lamp goes out. I cleaned the grounds and disconnected the ABR and reconnected to make sure i did not have any problems with connections. I started it this morning and it was -8' and it did not happen but i also did not start driving for at least 20 minutes
Old Dec 20, 2016 | 05:55 PM
cmriv's Avatar
What are your wheel speed sensor actual values? can you look at those? if you can go into all of these control units and look at faults then i would presume it isn't a module issue, more like a component taking all the systems down.
Old Dec 21, 2016 | 10:39 AM
Still no problem +8' this morning and i gave it no warm up time just threw it into gear and drove it normal, previous work may have solved my issue, i'll keep you posted
