E-Class (W211) 2003-2009
Blue tooth Audio upgrade using COMAND deck MoBridge M2 Pro Connect
Old Dec 24, 2016 | 12:36 AM
nathan116036's Avatar
2012 E63 2007 E500 wagen 1983 300GD (5.0) 1979 450sel 6.9 (multiple)
Hi guys,
for quite some time I've been annoyed about not being able to stream music through our E class main unit. It had a CD player but thats a bit dated. I did not want to install one of those Chinese abominations as i wanted to keep the original deck functioning. There are a few options but they all sounded a bit complicated. I bit the bullet and ordered the Mobridge M2 Proconnect. I already had Blue tooth phone audio and it was solely the streaming i wanted. The Unit effectively provides
-blue tooth telephone (if you dont have)
-blue tooth audio streaming
-USB input if you dont have
-auxiliary jack if you dont have
It was a real nuisance to install as there is nothing out there so I made this video which i hope helps some people determine if its what they want and if its the right thing for them. If i had clear instructions it wouldnt have been so hard. It works clearly and reliably although the head unit as a controller is not so crisp. I think Dension offered an alternative but i know nothing of it here in our neck of the world.
I hope the video helps.
Old Jul 26, 2017 | 10:43 AM
8899's Avatar
1994 E500, 2002 E320 wagon
How has this mObridge unit worked out for you so far?
Old Jul 26, 2017 | 11:21 AM
heh 8899.
after probably one year or so a few points
-music streaming to date has been reliable, works well. Does take some getting used to the controls. The ability to freely move through your unit does suck, but if you need to change folders, you can do it through your phone
-the bluetooth is like a tractor beam in the car. If im working in the garage, even with the car off, the bloody phone will keep getting 'sucked' into the car and the music will start playing through the car even if you are using another wireless speaker in the garage!
-the thing always starts off with the MBconnect when you turn the car on. ie even if you turned the car off listening to radio through head unit, when you turn the car on, its on the MB Connect units bluetooth which is a little annoying.
Ultimately, my wife mainly listens to bluetooth so its not an issue.
I think if you were a tech illiterate 70 year old you would battle but at least you can keep your factory unit!
Old Jul 26, 2017 | 02:06 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
I tried the Dension Gateway and had many of the same issues. Navigating the menu was a nightmare but the most annoying issue was having the Bluetooth pick up my calls while sitting in my office (car parked outside next to office). I retrofitted a Kenwood Navigation unit (DNX9990HD) via an Opti-One/NavTV module and it's by far the best mod I have done to my car. All annoying issues are gone.
Old Jul 28, 2017 | 11:30 AM
8899's Avatar
heh 8899.
Thank you for the additional information. I just picked up a 2008 G55 and have learned that the mObridge M2.Connect is the best solution. My G has the M-B bluetooth module, BUT I noticed that it also has some strange buttons and my iPhone picks up 2 bluetooth signals. See photos...do any of the 2 bluetooth photos look like my G may already have a mObridge or Mcar device installed???
Attached Thumbnails Blue tooth Audio upgrade using COMAND deck MoBridge M2 Pro Connect-img_3243.jpg   Blue tooth Audio upgrade using COMAND deck MoBridge M2 Pro Connect-img_3244.jpg   Blue tooth Audio upgrade using COMAND deck MoBridge M2 Pro Connect-img_3242.jpg   Blue tooth Audio upgrade using COMAND deck MoBridge M2 Pro Connect-img_3245.png   Blue tooth Audio upgrade using COMAND deck MoBridge M2 Pro Connect-img_3246.jpg
Old Aug 2, 2017 | 11:15 AM
speedracer.eric's Avatar
2003 E320
Has anyone tried the mobridge with an Audio50 with HK?
