E-Class (W211) 2003-2009
ESP, ABS, Brake Visit Workshop and check engine
Old Feb 7, 2017 | 06:57 PM
Myred8's Avatar
2005 E320 Sedan
I just purchased a 2005 E320 Sedan with 81,000 miles. I am a Corvette guy and know nothing about Mercedes. I would like any help to solve the demons that seem to haunt my car. I started with a low budget car and starting to get an education about codes that are on the dash. ESP, ABS, Brake visit workshop, and check engine light. It has a winning noise coming from the power steering and I replaced it with a rebuilt MB pump and new idler pulls. Also used MB power steering fluid and flushed fluid with a baster. The car still has the winning noise. Car will not shift out of 1st gear. I guess I got my monies worth with a cheap price. Any help would be appreciated. Maybe some of the members has had these problems or know how to fix them. Many thanks for help. Thanks Steve
Old Feb 12, 2017 | 05:18 PM
Myred8's Avatar
2005 E320 Sedan
Help with location of fuse
Recently I replaced my auxiliary battery that was old. That did not help with any problems that I have. One code says that the auxiliary relay does not open or fuse upstream is defective. Where is the fuse for the auxiliary battery? One post talks about it being near the auxiliary battery. I found the relay but no sign of a fuse near it. 2005 e320 thanks Steve
Old Feb 13, 2017 | 12:31 PM
cMazara's Avatar
w211 03'
1st replace the brake pedal light switch..
leave it a couple of hours and if it got the same message then hook it up with a mercedes scanner.
