P0025 Error Code Camshaft Magnets
I just replaced both camshaft magnets on the right bank (Drivers Side). The job was easy and parts were only $44.00 from MBOEMPARTS.
Dealer wanted a couple hundred each side to replace for me. I decided to only replace 2 on the right side instead of all four.It took less then an hour and I did not have to remove the power steering resovior. I just had to remove the lid. On the 2nd one, it came out easily when I unscrewed the camshaft sensor and removed.
you can rest the CEL light by erasing the code, you just need hit the erase button and turn off the ignition.
this was a piece of cake, save some $$$ and do it yourself.
2008 E350 4Matic. Good harmonic balancer verified
