Nav and Daylight Savings
Build date 2-04 E500
Originally posted by glojo
If you have a manual that has the heading Clock in the Index then I must be going blind because I cannot find it.
My E500 must have mind of its own.
I can't change the time using the SVC->time button,
It will allow me only to change the hour, and minutes (in 30 minute increment). I hit okay and nothing happens.
I can't change the date either.
Hey krispy....
Its spelled out for you on page 144 in the Operators manual. There it will show you how to change the hours, minutes, day of week and year.... Its all done on your steering wheel, Then push the reset button for two seconds to "confirm" on the left side of dash next to the clock.
Originally posted by HELL ONA HARLEY
I actually got the "clock" info in the Operators manual and NOT the command manual, so don't beat yourself up too badly..... Page #420 in the index references you to page #144 on how to set the clock.....
In the end I let my son have a go, and he annoyingly just played with the COMAND soft buttons and practically went straight to it. Grrrrrr (If all else fails, then read the manual)
I am surprised you have that option available, as well as being able to change it on the COMAND????
Thanks for the info.
John
Hey krispy....
Hey krispy....
#32
Originally posted by dr_shimanto
I have E500 with DVD NAV and CLK 320 with CD NAV. CLK updated automatically but E500 did not.
Nice hearing from you,
John
#33
#35
Press SYS
Select Time option
Use up, down, left. right arrows to adjust time/date etc
Good luck
Press SYS
Select Time option
Good luck
Some members describe how they can alter theres through the steering wheel 'Functions' as described in the main Owners Manual.
Regards,
John
