Mercedes W211 E220 CDI B28/5 & B5/1 Fault
Mercedes Benz W176 A180
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Hi guys,
I need help for my car Mercedes Benz w211 E220 CDI year 2003.
The car has no boost power and causing black smoke. The rev reaches only 3000rpm. Went the diagnose the car and the following faults was found.
DTC 2025-08: Check component B28/5 (pressure sensor downstream of air cleaner). The atmospheric pressure between Component B28/5 (pressure sensor downstream of...
DTC 0105-08: Check Component B5/1 (Charge pressure Sensor). The atmospheric pressure between Component B5/1 (Charge pressure Sensor) and component N3/9 (CDI co...
Can you assist please guys? Thanking you in advance for your support.
Regds,
Adil.
Regds,
Adil.
yeah, here are values:
the boost value shows 800 fix
the airmass varies -ve +ve value eg. -1200,-800, +1900, +2080 etc...
the atmospheric pressure remains fix 961
Mercedes Benz E 220 CDI. 646 Engine, 2006
Hello Dilatha,
Black Smoke at such a Low RPM. Start by Checking Leakages at the Nozzle areas, uninstall and Clean EGR and Also check that Your Intercooler isn't leaking Air. Smoking Means either Flooding Nozzle Injectors or Insufficient Air Injection into the Combustion Chambers. It could mean that you didn't use LowAsh Engine Oil.
Let me know what you find out.
