To fix or not to fix - that is the question
Now since I also have occasional 1st to 2nd hard shifts even after tranny oil replacement I'm wondering if it's worth investing another almost $2k while at 233000 km's (~144k miles). Is that considered to be high mileage for these cars or do people get much more life out of them? The car otherwise is in great shape, engine runs well and mechanic found no other issues.
Thanks for any input you may have
I have never replaces shock on any Mercedes my family owned and some of them were in 1/2 million km range.
144K miles for a Benz Diesel is NOTHING IMO! And the car is not even 10 years old.
How is the ride height? A broken spring on one side will result in lower ride height, and the vehicle will look uneven. Often what happens is the bottom coil will break, and it can be hard to see if you aren't specifically looking for it. Springs can also sag with age and wear, and you'll notice the ride height lower than usual.
The car being wobbly on the highway could also be a wheel bearing or ball joint issue, and you'll definitely want to check these items. If the shop that diagnosed the issue was competent they should have checked this.
