black smoke
I wouldn't use that. Or check with your indie pretty sure he'll offer free advise, or check interweb.
GL
2merks
Cheers.
it doesn't effect the startup, my w211 starts perfectly, I don't feel anything just the light on the dash
and the dpf probably I will try
thanks
Mike T.
in 2005, it was not a clean diesel.
Peter
I think you're okay with the smoke,
Peter
It might be late but i would like to point that i uave the same problem.
Failed my MOT because of exesive smoke. Everything in engine bay is brand mew, from filters to oil without any check engine lights and codes.
BUT, have you checked your intake manifold/air collector. Just unplug the the black big hose just before the grey engine cover and you will see that there ist black soot and with a high chance that the flaps are blocked ore even broken not letting enough air in the engine under hard acceleration. Best solutiin is to change the intake manifold or remove it and clean it.
Keep in mind that all diesel engines do smoke a little but anything beyond that is exesive and needs to be taken care of.
Hope this helps.
Hope this helps.
I am writing English for the others,
it seems a good idea and probably it is like you said
I know it is hard to remove and check/ clean, is there any way to clean it without dismantling? or if something is broken/ wrong can it be found by the scanner ?
faleminderit
faleminderit
It is not easy to detect a problem with a scaner because of the electro motor that alternates the flaps might be working so i does throw code but the connecting rodes to the individual flaps might be broken. So, as i said, just remove the hose that goves to the intake manifold, its quit easy just one metalic clip, and see for yourself if ts clogg
ed with soot.
faleminderit
Its a standart procedure for older cars as its a normal proces that happen as the car gets driven through the years.
So ive took my W211 to a mechanic lately to have my intake manifold checked and cleaned. First, the moment he removed the first metal pipe that comes from the EGR valve and i was a little shocked although i knew that it had some 240k km on the clock and that was more or less normal (pic 1). After all the bolts had been undone and the manifold was out, i was even more shocked. As seen on the 2nd pic, the manifold was as new as i could have ever imagiened. All the flaps were clean and the all the links to the servo motor were nowhere near to broken. So... with all the pipes and EGR cleaned with cleaning solution and cheap diesel and back on the motor block, ive thought that the black smoke was for ever gone. Nope. Although the motor seems to run a little smoother the smoke is there. After all i had to take my car to another specialist to have my injectors checked. He said that when the smoke continues to exist, the last problem has to be one ore more partly blocked injector. AND the cleaning cost for 1 injector was 100€. Aaaaa....
Ill keeo you updated when i have the money and time to have this last service on my car done.
Hope all this helps even a little to understand the problem on those old but reliable cars.
my 220 w211 when its cold in the morning after it is turned on, when gears engaged D or R it starts smoking and then switched off immediately, I doubt it is related with the air but I should open the intake manifold first
