E-Class (W211) 2003-2009
Bypassing malfunction notification
Old May 12, 2017 | 11:55 PM
Steve_k_550's Avatar
W211 E550
Has anyone successfully bypassed the airmatic malfunction symbol after a coil spring conversion
Old May 13, 2017 | 02:27 AM
cMazara's Avatar
w211 03'
I think that you have to disable the airmatic via das/xentry
Old May 13, 2017 | 03:24 AM
W211 E550
Damn !
Old May 13, 2017 | 11:28 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Check Arnot site. They should have dummy chip.
Old May 13, 2017 | 02:05 PM
mociclistu's Avatar
Mercedes ML350 Bluetec W166
I also have this problem.
I own a E280 CDI T-modell from 2005 and i made the conversion on the rear with Arnott springs.
In the instructions they say to remove the connector from the rear suspension unit, and after that , no error came on dasboard, but SURPRISE in the night. The xenon headlights doesn't make anymore the autoleveling, because te rear axle sensor .
So i was forced to put the connector back and remain with malfunction in dashboard, and the xenon autoleveling works again.
I did send this infos to Arnott and they passed the problem to their research and development department. Hope that anyone figures this out.
Old May 13, 2017 | 04:54 PM
W211 E550
Arnotts refuses to sell their bypass module separately
Is it possible to install resistors to trick the signal ??
Ps I couldn't be more happy with the coil springs
Old May 13, 2017 | 06:58 PM
W211 E550
So with their module does it simple plug into the rear harness and no splicing of the wires is correct
Would you be able to post up a photo of their module , I'm pretty sure this unit could be made up with resistors spliced into the front and rear sensors
Old May 14, 2017 | 04:25 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Try using a multi-meter to measure the in-line resistance of the solenoids in your now-removed air springs.
Old May 14, 2017 | 04:30 PM
W211 E550
Good idea will try that out some time today
Old Feb 18, 2023 | 01:34 PM
Boreks's Avatar
Mb e320(w211)
Exactly where in xentry/das you can disable Airmatic ?
Old Feb 18, 2023 | 01:39 PM
Boreks's Avatar
Mb e320(w211)
Where in xentry/das I can manage disabling Airmatic?
Old Feb 21, 2023 | 11:53 AM
lkchris's Avatar
'10 CL550, '12 GL550
Ha! The autoleveling works by adjustment of the inflation of the air springs.
