E-Class (W211) 2003-2009
Help with ac
Old May 13, 2017 | 10:15 AM
Drew Browder's Avatar
2004 E320 wagon 4matic
Help with ac
Hey,
First off let me just say thanks for any help you can shed on my problem. Okay now I force my car to a friends house about 40 min away and the ac was blowing cold as usual. I left the car there for a 24hr period and when I got back, very late at night, I had to turn on the defrost for the windshield and I went from the cold temp setting to the hot. Once the windshield was clear I went back to the cold setting and I get no cold air. Now first thought was that I am out of coolant (or refrigerant) but my ac seats still blow out noticeably cold air. I'm by no means rich so I need to diagnose and fix this problem myself because I cannot afford to take it anywhere.
Old May 13, 2017 | 10:36 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
With at least 9 sensors directing AC work - reading crystal ball is having its limits.
Do the sensor readout per http://www.mercedesmedic.com/ac-air-...le-codes-list/
If you have climatronic with REST button and LCD display, the procedure is similar to older models on the site.
If no REST, you need to use computer.
Old May 13, 2017 | 02:56 PM
I also have the LCD in the gauge cluster but I'm getting nothing from either. Also the light rest button doesn't light up or blink
Old May 13, 2017 | 05:27 PM
kajtek1's Avatar
You need scanner to read AC sensors and errors.
I got so spoiled with troubleshooting AC with tip of the finger at 70 mph, that I installed climatronic with REST button on our 2008 Bluetec.
With some luck you will find one for $40 and it is plug & play
Old May 18, 2017 | 04:27 PM
Ok I've purchased icarsoft i980 and running through the test it has, I'm showing no fault codes and it even goes as far to tell me if motors in the right positions for different zones and the aren't showing malfunctions either
Old May 21, 2017 | 06:02 AM
PSDCampervan's Avatar
2005 E320 CDI (SOLD); 2008 ML320 CDI 4MATIC
Duo-valve might have stuck open?
