E-Class (W211) 2003-2009
Cooling issue
Old Jun 13, 2017 | 09:51 AM
imaslev's Avatar
w211 E63
Cooling issue
Hi there
I have an issue whit my cooling if I run on open air and push hard my oil will go to 100c' and the coolant will rise to 90 c'
But in traffic oil go to 120c and coolant as will for a moment and then all fine
Suggestion!!
Old Jun 13, 2017 | 11:44 AM
imaslev's Avatar
w211 E63
Originally Posted by Plutoe
I would strongly suggest that you have a coolant flush done then use the correct coolant distilled water mix and inspect all the hoses, then depending I may also change out he thermostat------------I would also make sure that I have the proper amount of engine oil!
I just did service B with a coolant flash at MB dealership
I guess my next step is thermostat cuz I think the fen is bowling after the temp. go hi
