Can't enter service menu ?!?
Hi
So i just did my air filter but can't enter the service menu to log it.
Position 1 (the first click) and then 3 quick odometer reset button pushes. Nothing.
What am I doing wrong?
E280 cdi 2008
E280 cdi 2008
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
'99 and '05 E55 AMG
-Set display for "Service x due in xxx kilometers".
-Press and hold reset button (lower left of display panel) for 5 seconds.
-Use + or - buttons to scroll up or down.
-Use the "folder" button to select. "Items" will show you what service items should be performed. "Confirmation" allows you to confirm service was completed. (-Use + or - keys to scroll up or down in the sub-menus then use the "folder" button to select.)
Key must be in position 2 for the above.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
then 3x R and u will enter a mode
us see 12.5 volts, scroll in the menu
greetings
