E-Class (W211) 2003-2009
Need Help, Should I Buy?
Old 06-19-2017, 11:22 AM
3putpro's Avatar
Acura TL
hey guys,
so I found a 350 that I really like but having read a lot about the problem with the balance shaft, I'm concerned. It's a 1 owner car. Here's a link to the Ad and here's also the vin. Any help or thoughts you may have I would greatly appreciate!!
http://www.karkraft1.com/2006_Merced...H_10810092.veh
WDBUF56J16A770352
I know there's a way to look up the engine number etc. but hoping someone has some more expertise than I do.
Old 06-19-2017, 12:42 PM
cetialpha5's Avatar
Received 1,506 Likes on 1,177 Posts
There's no need to look up the engine number. All 2006 had the balance shaft problem and they also had SBC brakes which can be a 2k repair. With that kind of mileage, if it hasn't been replaced, it can need it at any time. Shoot for 2007+, that had the facelife which I think is a nicer interior and got rid of SBC brakes. Some early 2007 also had the balance shaft problem so you still need to check the engine number on the VIN. Cars basically made before September had the problem and the updated parts was sometime after September.
Old 06-19-2017, 01:15 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
I'd avoid the 03-06 models unless you're going for an E55.
Old 06-19-2017, 03:35 PM
konigstiger's Avatar
Received 4,448 Likes on 3,155 Posts
'71 Pinto
Engine # 30 053296 is within affected range clean point as of 30 468993 you can have MB dealer check vehicle master inquiry (VMI) to see if balance shaft was repaired.
File Type: pdf
Old 06-19-2017, 04:26 PM
kajtek1's Avatar
Received 1,749 Likes on 1,394 Posts
1922 Ford Model T / no OBD
There is a reason why those cars sell co cheap.
Try to buy the same year/mileage Bluetec and you will have a chance to figure it out.
Old 06-19-2017, 04:40 PM
Maroc_Specops's Avatar
W211 E320 CDI Sportpackage With Carlsson CD32 Chip 2004
SBC sint a 2k repair anymore. maybe in 2005.
1000 $ in 2017 for a new pump with labour 75 dollar.
Quick Reply: Need Help, Should I Buy?
