E-Class (W211) 2003-2009
E350 maintenance
Old Jun 28, 2017 | 01:55 PM
Tortoise's Avatar
2012 E350 4matic
E350 maintenance
What is the proper plug change interval for an E350 4matic? The guy I bought it from wants almost $500. The car has 60000 miles.
Old Jun 28, 2017 | 03:50 PM
konigstiger's Avatar
'71 Pinto
Every 60,000/6-years whichever comes first, see attachment.
File Type: pdf
Old Jun 29, 2017 | 12:24 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
There are several DIY threads on changing the plugs. It's not hard at all.
Get the plugs from FCPEuro as they are having a sale. I just picked up mine from them.
https://www.fcpeuro.com/products/mer...bosch-yr7mpp33
Not sure if those are YOUR plugs, so make sure you change the drop down menu.
EDIT: These are what are popping up for your make/model.
https://www.fcpeuro.com/products/mer...sch-0041598103
Or
Get this kit and you can change the plugs for as long as you own the car:
https://www.fcpeuro.com/products/mer...t-bosch-517012
You'd save $400 doing this yourself....
-Nigel
Old Jun 29, 2017 | 02:03 PM
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
He's got a 276 motor. Different plug, plug tool, and procedure as the plugs need to be clocked in the head, he needs this guy
--Kyle
Old Jun 29, 2017 | 03:08 PM
cetialpha5's Avatar
Or
-Nigel
He's in the wrong forum. For 2012, they went to a different engine that used direct injection. I think it's a 60 degree block instead of the 90 in the 272. Anyway for whatever reason, you have to take the intake manifold off in order to change the plugs so it's a lot more complex than the 272 engine. For the 272 engine, they're rather simple, I think mine were done in less than 20 minutes. That engine also went to a multispark system that fires up to 4 times per cycle so that 60k interval is also right.
