Help. Stuck motor mount.
Googled what I could, over and over I heard you need an offset 16mm wrench to get at the top bolt. I ignored that advice. The bolt is a straight shot and nothing 16" extension and a universal joint couldn't reach.
The top bolt came out super easy. Crawl under to see what the situation was down under. Removed the under tray and found the lower bolt in between where the lower control arm mounts to the sub frame. Research told me that the exhaust had to be dropped or to remove the alternator and a.c. compressor, but it looks as the will com right out the side of the engine bay.
Grabbed my ratchet and 13 mm socket and began to loosen it. Turn after turn nothing. Slid over to the other mount and the same thing. Would the factory have overtightened these to where they stripped them?
Anyone run into a similar issue or have advice on how to proceed? Short of drilling it out and getting replacement bolts I'm stumped.
