rear defroster not working (but it gets voltage)
2005 e320 CDI, 2010 ml350 bluetec
it was working fine, now its not. The relay is fine, the fuse is fine. if i disconnect 12v input from the antenna amp module in the c pillar, reads 12v on the DMM, if i connect it, then it drops to ~3v or less than climbs a little. on the output side its 0v (amp - window). I replaced the module, and still the same. checked the wiring on the SAM/relay box and everything looks good.
