Stumbling at low RPM
My 2006 E320 CDI has been stumbling at low RPMs after restart with engine at operating temp. It is not constant, symptoms similar to what I would describe as a vapor lock on a gas engine or perhaps water in the fuel . DAS interrogation shows all normal values for compression and injector values, normal quantity and pressure control valve tests. No signs of injector seal leaks. No codes are present. Seafoam run through tank.
Just replaced the fuel filter, symptoms still there.
Thoughts?
John
Thoughts?
John
Thoughts?
John
Thoughts?
John
John
