Need info on HK logic7
ML-350, Maserati Quattroporte
Hope someone can help. I have HK Logic7 and I'm pretty sure I have a problem the dealer is blowing off. What I notice is that if I put the balance all the way to the back all I get is distant muffled sound. If I shift balance centered on the rear seats I pretty much have all sound comming from front speakers with little if any sound contribution from rear. This causes distant hollow sound. If I sit in the back seat and center balance to middle of rear seats the sound is not great. I basically don't hear anything substantial comming out of the rear door speakers. The rear shelf speaker also sound very distant.
Is this normal. What do I tell the dealer since they give me the old: "sounds OK to me". Any info would help. If any one out there could test shifting sound to rear and telling me what it should sound like I'd appreciate it.Thanks.
S4
Re: Need info on HK logic7
Build date 2-04 E500
Re: Re: Need info on HK logic7
Originally posted by moa4r
seems like you have a problem;; shifting the fader to the rear makes all the sound come from the rear speakers as it shoudl; ask your service manager to try doing it on any another e-class at the dealership and see what happens...GL
2015 ML 350
I have found that when the sound is set to "surround" it is electronically altered, and when the balance/fade is set to center, it is dificult to tell what is coming from where...the car is just "filled with sound". Try it in the basic stereo mode, where there is a much more artificial separation between left & right. You might be able to tell then.
05 C320 sport coupe
When laying out a quality sound system, the #1 rule is that the sound should come from the center front of your car. It should emulate being at a concert or show. When was the last time you were at a concert and had your back to the stage? ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Ive never tested the fader so I dont know if you have a problem, but most of your sound should be coming from the front
2015 ML 350
I think the sound should fill the car not just eminate from the front. In a concert hall big money is spent on accoustics in the hall so that the sound seems to "fill the hall". You should, however be able to tell what instruments are located to the left or right side of the theater.
Thanks for info guys. I did check balance in stereo mode and you are correct that there is a difference . Either way I have noticed this problem after the audio gateway update I got recently. I'll take your advice and get to the dealer with a good CD and check out the difference. Bottom line is that my sound is more distant, hollow and shallow.
CAPTMIKE, yes I did thank you. I've previously tried your algorithm to check my system and nothing happens. Probably corrected by gateway update. Thanks, and I'll keep you updated.
2003 E320
