Rear Quarter Window Seals
My rear quarter window seals are cracked. Dealer says these seals cannot be purchased separate. Rear Glass has to be included with the seals which I see is ridiculous and overpriced. Any ideas on this?
LoCoRob (06-04-2021)
Received 4,441 Likes
'71 Pinto
Correct, shop used.
E55 AMG, Audi Q5 TDI
Gangrene3075 did you ever find a solution? I have the same issue and need to replace the rubber seals. Not only are they cracked but also gooey.
Wizo - Last time I was looking into this...The entire Rear Quarter Window has to be replaced in order to get a new seal. My seals still looks the same now as pictured. If you find anything different, please share.
I went to replace the belt molding on the rear door and my seal was cracked so bad some pieces just fell completely out. Thankfully it doesn't rain much here, but it sure would be nice to get that fixed.
That’s the same story I got. I have the same problem on both my rear quarter windows.
Coming in for the revive! CLEAR! https://www.mbpartsus.com/p/mercedes...207350124.html
for s500 seams you can buy the seal but for yours whole window 166.40 per side not bad I would put some ceramic coat on them before i put them in
