E-Class (W211) 2003-2009
Bad axle or did I break?
Old Sep 23, 2017 | 09:32 PM
pbeamtn's Avatar
2005 E500 4Matic wagon
On my '05 E500 4matic, I decided to replace the front axles since the boots were split, I was getting noise when turning, and one of my front airmatic struts failed. I had a lot of difficulty on the left side, and when I got it together, I just get a grinding noise from the left side when the transmission is in gear. When I took the axle back out, I find the inner joint is the problem.
So, since this is a brand new axle, I am hesitant to open it up and see if the bearings have come off or if there are other problems. Is it even possible for me to mess it up? It is possible I extended the axle too far as I did have trouble getting it to compress when I went to attach the wheel. On my old axle, I have extended them too far and had to work to get them back in, but the boots are almost non existent. Is it possible to extend too far with the boot and then have things come apart?
If I open it, is there an easy way to put the clamp back on?
Old Sep 24, 2017 | 10:59 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
What new axles did you use.?
Inner joint will split when you pull it out. There is nothing to hold it together but some rubber boot overlap.
Old Sep 24, 2017 | 12:33 PM
Ottin's Avatar
2005 E320 4Matic
If you still have the original shaft, you may try to rebuild by yourself, replacing inner and outer boots at the same time is not so hard because inner ring is much easier to take it off.
The $100 aftermarket shaft was verified a wasting of money.
after removing shaft, it's a good time to replace old air strut and upper control arm together.
Old Sep 24, 2017 | 02:15 PM
pbeamtn's Avatar
Based on this, I am going to open the inner and see if I can put things back together. I found a $12 band clamp tool at Northern Tool today, and I hope it works. I do have the original axles, and know I could rebuild if I need to, but I am going to hold this as a last resort.
I have already replaced just about everything in the front suspension.
Old Sep 27, 2017 | 08:37 PM
pbeamtn's Avatar
To close out my own thread, I had pulled the inner CV joint apart. The solution was to remove the band, dig in the grease to find the parts, and then put things back together. This design has a cage with 3 ***** for the inner joint. The cage and ***** were apart in the boot.
