E-Class (W211) 2003-2009
Question Abt Speedo Trip Computer '04 E
Old Apr 30, 2004 | 06:25 PM
Barry45RPM's Avatar
2015 ML 350
In the center of the speedo you can see your stats since the last start or since your last reset...
What is meant by 37:35 H (37<colon>35?
Does it mean 37 hours AND thirty five minutes?
Does it mean 37 hours AND thirty-five HUNDRETHS of an hour, as in 37.35 (37<point>35)
I tghought Europeans use a , <comma> where we use a . <period> to note decimals.
If so, roughly how many minutes is a hundreth of an hour off-hand?
Old Apr 30, 2004 | 07:12 PM
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
Offhand, I would say that 1/100th of an hour is 36 seconds, or 0.6 minutes. I suspect that the number after the colon refers to minutes, though, not hundredths of an hour. I don't recall seeing a number higher than :59 there, anyway.
Got a question of my own. Are the "Since Restart" values supposed to reset EVERY time the engine is started? That's what I would expect, but that doesn't always happen with my '03 E500. Sometimes it carries over the previous values after the engine is restarted in the course of a day. I've never noticed it to carry over values from one day to another.
Old Apr 30, 2004 | 08:51 PM
Barry45RPM's Avatar
2015 ML 350
No, not every time you restart. The engineers took into account that you might be on a road trip & stop at a rest area for lunch. I forget how long after an ignition shutdown it is wiped clean, but it is in the owners manual (library). I think it is after a shutdown longer than 2 hours, that the slate is wiped on that screen.
Old Apr 30, 2004 | 09:44 PM
rbordel's Avatar
05 E320 CDI
Actually the "since restart" reset timeout is 4 hours, at least on US spec E's.
