E-Class (W211) 2003-2009
E500 Shock problems..
Old Apr 30, 2004 | 11:15 PM
alevy's Avatar
2003 MB C230K Sports Sedan
Unhappy E500 Shock problems..
Can someone tell me if there is a TSB or some kind of bulletin relating to the shocks in the E500 sport? Specifically the rear.. Mine are going in to be replaced for the 2nd time in 6 months..
Thanks..
Old May 1, 2004 | 08:55 AM
BudC's Avatar
2011 E550, 2013 GLK
Did the S-Class have problems with it's air suspension? Maybe it was a higher quality system.
Old May 1, 2004 | 01:33 PM
rusnakmb's Avatar
E500
Hi,
The S and E have different airmatic. The S uses one unit airmatic with build in shock. The E is different. The E has airmatic to hold the car's lever, but use a adjustable air-shock. It is a 2 unit airmatic. The air-shock often leaks.
I hope you have purchase the extend warranty. For what I know, these air-shock probably need to replace pretty often. Maybe 30k to 50K......
One good news is that the air-shock is lot cheaper than S airmatic, which is aboout 1k for parts.
Old Oct 14, 2009 | 10:15 PM
Benzo1999's Avatar
2003 E500 Sport, 1999 ML430 & Regal 402 Commodore
After dealing with blown rear shocks for two seasons, I have decided to a little research of my own. I discovered alignment has a huge impact on how the rear end tracks. If your toe or camber is off; the car will "bounce" like it has a blown shock.
I took the car to the alignment shop and insisted that the tech aligned the car to the exact specifications on all four wheels. Wow...what a difference, the car stoped bouncing.
I can't guarantee this will fix your issue, but it did help mine.
Good luck
