E-Class (W211) 2003-2009
Airmatic help
Old Oct 9, 2017 | 04:21 PM
Brentlez's Avatar
E63
Airmatic help
I have a 08 E63 and my diver side rear air bag popped so i replaced it and now nothing works. The front end is stuck in the raised position and the rear is on the floor. The compressor will turn on if i jump the relay and every other key on engine off the compressor will turn on for 2-3 seconds then turn off. If i cycle the modes nothing happens. The fuse and relay are good. No leaks and all wires are connected. The only dash light on is suspension to low. Not sure if i have to just reset something or it has to be taken to a shop to be connected to star. Any help is appreciated.
Old Oct 13, 2017 | 04:21 PM
jevlar's Avatar
E55 -05
Sounds like you need to connect to star or aftermarket diagnostic tool and check level sensor values and reservoir pressure.
