E-Class (W211) 2003-2009
MAP Vacuum Hose.. where it ends?
Old Nov 5, 2017 | 12:51 PM
cMazara's Avatar
w211 03'
Map sensor hose (86 in the pic, cel code p0106) is cracked.. is the hose 119 in the picture? where it connects to? I think I have to move the secondary air pump out of the way.
it's just a plug n play to the manifold?
I believe the hose is 3.5 mm Inner Diameter, correct me if I'm wrong. part number 1179970982
Also replacing the other two other 119 hoses with this.
Also, what 9/64 means in the hose specs? Size:9/64" 3.5mm Inner Diameter Color:Blue
Amazon Amazon
Lots of questions I know
Old Nov 6, 2017 | 11:12 AM
cMazara's Avatar
w211 03'
Old May 11, 2023 | 08:47 AM
mkhounani's Avatar
E350
Hi, I'm new so forgive me if my post is misplaced but This is the only source I could find. Does anybody know in 2006 E 350 where all the vacuum lines out from the Intake Manifold go to? Thank you.
