Wiper washer & level 1 speed wiper problem
i got a problem with my w211.061
washer fluid don’t work and wiper speed level 1 isn’t working also
No fault codes on FRONT SAM
but i have XENTRY and test the washer it working properly, i tested the multifunction switch also getting line perfect.
check all fuses box from front-beside steering wheel, also on rear fuse box none fuse were broke
finally testing voltage through pump washer 11-12v
same as instructed on XENTRY diag
Any idea what should i do next?
or maybe anyone has wiring diagram so i need to check?
thanks for your reply 😃
:sad
