Sloppy Auto Transmission Shift Lever FIX
Ordered up a couple of these grommets from FCP as they are not expensive. "Mercedes Manual Trans Shift Rod Bushing - Febi @ $1 each: 2109920010"
Now there is not a lot of room between the tunnel and that linkage to get your hand up in there to try to install that bushing on the transmission input lever. What I did was remove the spring clip that holds to linkage bar "pin" to the input lever with a long set of needle nose pliers. I cut the "lip" off of only one side of the rubber grommet. Then installed the grommet on the linkage rod "pin" with the remaining lip side of the grommet towards the rod. This is not factory as they would have you install the uncut grommet on the input lever first as designed. I lubed up the grommet and was able to easily push the linkage rod into the transmission input lever. Sounds sexy I know. Then push on the retainer clip and your done. Easy cheap quality-of-life fix.
