E-Class (W211) 2003-2009
Front wheel camber
Old Jan 3, 2018 | 12:15 AM
Slickj's Avatar
E320
Front wheel camber
2003 e320 lowered on 19s anybody know how to fix the negative camber on front wheels
Old Jan 3, 2018 | 12:43 AM
kaane's Avatar
2004 Mercedes E500
The front camber can be slightly adjusted with the eccentric bolt kit. Part number A000 330 0018.
I would check your toe if you are seeing tire wear. It contributes much more than camber.
Old Jan 3, 2018 | 04:23 AM
Kamisama's Avatar
E500; ML63; X5M; LR3
A good body/frame shop can adjust camber back into spec. All wheel dynamics are important when doing your alignment, but if you have a camber problem then fix that before moving on to the rest of the adjustments. Make sure your bushings are all good before anything else.
Old Jan 3, 2018 | 10:41 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Your car is lowered so you have limited options. Using the so-called "eccentric" bolts from Mercedes will only buy you a reduction of 0.3 degrees camber (i.e. if the front is currently at -2.3 degrees then installing the bolts will only bring it to -2.0 degrees).
If you insist on running the car with lowered suspension, you can install KMac bushings in the front. I've been running a set for almost 2 years and over 37,000 miles. They aren't cheap and you have to pay to install them and re-align your car but they work well.
