ABS, ESP, Run Flat indicator, Speedometer inoperative
2007 E350 4MATIC Sport
Can someone please assist me?
I have a 2007 E350 4Matic (W211) and I recently changed my low beam HID headlight bulbs (D1S -35W) with cheap bulbs I found on Amazon. They both flicker when turned on and eventually one lights and the over tries to light and sometimes it does and sometimes it doesn't. The same day that I drove with these new, garbage bulbs, the yellow triangle and ABS warning lights appeared on my dash and the malfunction display stated:
ABS, ESP inoperative, Run Flat indicator inoperative, Speedometer inoperative
I also have limited power steering.
Could these issues be caused by a brake switch malfunction? Could it be just a coincidence that these problems started immediately after replacing my HID bulbs? I have ordered name brand bulbs to replace these garbage bulbs. Am I causing additional damage by driving the car in this state?
I would really appreciate guidance regarding these issues or a redirect to a thread that addresses these issue.
2000 E320 2009 E550
I have never seen the yellow triangle light appear before. What do you think the cause is?
Replace the fuel filter
I have same problem in last days. On electronic diagnosis i have that error ,,Low Pressure Fuel System Sensor Circuit Low" or something like this.
In fact, due to the cold temperatures of the last period, the water in the fuel filter has frozen and slowed down / blocked the fuel flow. In my case the
engine started and stopped in a few seconds with the same errors with SRS and RUNFLAT plus the yellow check Engine Check Engine.
It has been solved very simply by replacing the fuel filter. Even if you probably solved the problem, maybe someone will need this answer.
Sincerely, George.
Sincerely, George.
